e6420 overclock and motherboard
Caporegime
20 May 2007
Surrey
Hi
correct me if i'm wrong but will a e6420 overclock well to 3.0-3.4ghz? If so would this not take it up to and beyond the x6800's extreme performance?
Also what would be a good motherboard to go with this and a 8800gts/gtx(possibly sli later on)?
Ive been looking a the gigabyte 965p DS3 (there is a P version as well but i cant see the difference)
any help would be appreciated
cheers.
Nope, as the 6800 is a Quad Core CPU.
Asus P5N32
Jono8 said:
I've been looking a the gigabyte 965p DS3 (there is a P version as well but i cant see the difference)
The DS3P has some changes in layout and native 1333fsb support
Asus P5N32
cheers, but isnt that the qx6800? I mean just the x6800? so would the dual core x6800 have *** same performance as the e6420 at 3ghz?
aha sorry misread, that's been discontinued afaik, but yeah should give the same performance.
Wicked. Do you reckon 3ghz would be an easy overclock on the e6420?
