- 7 Feb 2004
I have just changed my case and dont have as many fans inside at the moment.
I am running my CPU at 3.2ghz as that was stable in my last case but the temps are a bit higher in this case as it only has 2 120mm fans.
Its running at 65 and 60 on the cores on full load.
Is that ok?
Running tests on it now, ok after 30mins so far
THanks
Is that ok?
THanks
