I have a E6550 that i want to overclock.
My rig is:
Asus P5K SE
2x1gb OCZ Gold DDR2 PC2-6400 / 800mhz
Arctic Cooling Freezer 7 Pro
E6550 2.33ghz stock
I currently have it running at 2.8ghz. Current temps are 22c idle and 39c load using Prime95.
Would like to get 3-3.3ghz, problem is im not too sure what to do with voltage and ratio with ram. I currently have both on auto.
Also my case has a cpu air duct thing, was wondering if i should take it off since my cpu cooler is on the side.
My rig is:
Asus P5K SE
E6550 2.33ghz stock
