FrostedNipple said:blimey, that is high, iirc 90C is the melting point of silicon![]()
but if this is a new build check your mobo bios up2date etc, weni first built mine it wasnt, i updated it and boom 10degrees knocked off!
That's not the advice you should be givingjongeeone said:if its not overclocked then you got unlucky and have a concave IHS - search the forum for 'lapping' - should sort eh temps out
I don't think you know what your temps are?nbkpsycho said:I am using a stock cooler on my E4300 with 1.45v goin through it and it doesnt even reach 60c+ when stressed![]()
Thank god, some good advice at last!Justintime said:Has anyone asked what hes used to get the temperatures? it might be a software error or misreport you know.
ferret face said:my E4300 also runs at 83 degrees at full load according to Core Temp, I've tried different heat sinks but it make no difference to the temps.
I think quality control on these Core Duo's is lacking somewhat as some are very cool while others like mine are extremely hot.
peetee said:Quality control is actually lacking on coretemp, not the core2duos. Doesnt make a difference how hot the c2ds run, aslong as they do it safely at stockclock+volts.
Anyway, coretemp is offset by 15degrees, you're actually at 68 with that 4300.
Quiet yet still aircooled, a nice combo
