Hi guys,
I currently have my E6600 at 3.4Ghz with it at 1.425vcore. My temps are 50C under a full load with my Boinc folding program running both cores
. I have a Zalman 9700 turned up to about 2100rpms (2500rpms is maximum)..
I'm wondering whether or not to change the heatsink to the Thermalright Ultra Extreme to lower the temps further and try to get a bit more out of it, would it be worth it or should I just buy another CPU altogether? For the fan side of things, I have a YS Tech 120mm model, but its the 38mm thick model so my trusty Nexus fan controller will come in handy...
Would it be worth it and would it lower my temps to a more overclockable level?
I have a Coolermaster Stacker 810 case, with 2 120mms at the front, 1 120mm at the rear, 1 120mm on my PSU (OC Z 520W Mod Stream) and a 80mm at the top of the case. I could move the PSU to the bottom of the case and put 2 80mm fans at the top of it, if that would help with temps a bit further.
Would anyone care to suggest what would be best to do for me please??
. I have a Zalman 9700 turned up to about 2100rpms (2500rpms is maximum)..I'm wondering whether or not to change the heatsink to the Thermalright Ultra Extreme to lower the temps further and try to get a bit more out of it, would it be worth it or should I just buy another CPU altogether? For the fan side of things, I have a YS Tech 120mm model, but its the 38mm thick model so my trusty Nexus fan controller will come in handy...
