Hi, i have the following set up:
E6600
2GB Geil Ultra PC2-6400
P5W-DH Deluxe
I have the E6600 running at 3GHz and a FSB:RAM ratio of 1:1. My bus speed is rated at 333.5 (cpu_z reading) and my multiplier is x9; CPU is running at an effective FSB of 1334. I have the CPU_voltage set to 1.375 in BIOS, though this is actually running at 1.336 according to cpu_z. Memory voltage is 2.3V with timings of 5.6.6.18
I have this set up as i was informed the 1:1 ratio means there is no delay caused by one component waiting for the other. The problem i am having is even with the Artic Cooler Freezer Pro 7, my CPU idles at 50 degrees (TAT readings). I am also concerned at the poor timings for my RAM, which is only being rated as 5300 due to the low FSB.
Anyone got any ideas as to whether i should up the RAM FSB, and lower CPU voltage? Or anything that may lower the temp of my CPU without affecting performance? Or do you think the heat sink is just not seated happily, as everyone else i have seen with a freezer pro 7 is posting temps a lot cooler than this.
(Other info: Case is an Antec Titan, 2x92mm intakes at front and a 120mm exhaust at back)
Thanks in advance
E6600
P5W-DH Deluxe
Thanks in advance
