- 7 Mar 2005
- Eating PI
Spec in sig.....
I've now tried everything and the max I can get out of my Conroe is 3.36ghz...
Max is:
Cpu Multi @ 8x
Bus spd @ 420mhz
= 3.36ghz
or
CPU Multi @ 9x
Bus spd @ 365mhz
Other settings are:
Vcore @ 1.45v
Vdimm @ 2.2v
MCH @ + 0.1v
FSB @ + 0.1v
Idle @ 28deg
Upping the vcore does nothing, tried it all the way up to 1.575v with no clocking difference.
Upping the MCH or FSB voltages any further just results in having to reset the bios again.
Slack timings @ 5-5-5-15
Stock is 4-4-4-12 but some people have had this ram running @ 3-4-3-9 @ 400mhz (which mine won't do)
Any ideas???
Personally I think it's this motherboard, limiting me. Be very suprised if the CPU is maxed!
Max is:
Cpu Multi @ 8x
Bus spd @ 420mhz
= 3.36ghz
or
CPU Multi @ 9x
Bus spd @ 365mhz
Other settings are:
Vcore @ 1.45v
Vdimm @ 2.2v
MCH @ + 0.1v
FSB @ + 0.1v
Idle @ 28deg
Any ideas???
