18 Apr 2007 at 18:50 #1 IceShock IceShock Soldato Joined 16 Dec 2005 Posts 4,054 Location Halifax W'Yorkshire hello there. im just running my cpu at a nice steady 3ghz and have done for past 3 months. would it be worth taking it up a bit to 3.3 or 3.4 ghz? thanks
18 Apr 2007 at 18:58 #2 RaiderX RaiderX Soldato Joined 18 Feb 2007 Posts 3,159 Location Wirral should get to 3.4 no probs
18 Apr 2007 at 18:58 #3 IceShock IceShock Soldato OP Joined 16 Dec 2005 Posts 4,054 Location Halifax W'Yorkshire oh and plus if i take it up, my ram will be at 450mhz. i currently have it at 416mhz at 4-4-4-12. would the timings be fine still at 450mhz or will i need to take the ram voltage from 2.1 to 2.2v ? thanks
18 Apr 2007 at 19:08 #4 IceShock IceShock Soldato OP Joined 16 Dec 2005 Posts 4,054 Location Halifax W'Yorkshire im at 3.2ghz 355x9 444mhz ram at 5-5-5-18. would my ram be able to cope at 4-4-4-12 at that mhz do you think? thanks. btw im testing it now. no errors so far, full load at 41c at the moment
18 Apr 2007 at 19:10 #5 RaiderX RaiderX Soldato Joined 18 Feb 2007 Posts 3,159 Location Wirral set your RAM to run 1:1 with CPU, then RAM should be same FSB as CPU (355MHz)
18 Apr 2007 at 19:10 #6 IceShock IceShock Soldato OP Joined 16 Dec 2005 Posts 4,054 Location Halifax W'Yorkshire to get that, do i use 666 setting as the ram frequency?
18 Apr 2007 at 19:11 #7 IceShock IceShock Soldato OP Joined 16 Dec 2005 Posts 4,054 Location Halifax W'Yorkshire aka the one below pc6400 setting? oh and plus for 3.4ghz what voltage do you reccoment, its a L630b core. the voltage is on auto at the moment, whats the stock voltage btw?
18 Apr 2007 at 19:12 #8 RaiderX RaiderX Soldato Joined 18 Feb 2007 Posts 3,159 Location Wirral put it to double the CPU, so 355 x 2 = 710. post a SS of CPUz to see exactly what your settings are currently at
18 Apr 2007 at 19:14 #9 IceShock IceShock Soldato OP Joined 16 Dec 2005 Posts 4,054 Location Halifax W'Yorkshire its at 5:4 at the moment. so i need to change the ram to double the cpu frequency for it to run at 1:1?
18 Apr 2007 at 19:14 #10 RaiderX RaiderX Soldato Joined 18 Feb 2007 Posts 3,159 Location Wirral change it from 5:4 to 1:1
18 Apr 2007 at 19:21 #11 Cupra Cupra Permabanned Joined 12 Feb 2007 Posts 8,731 Location Teesside dont run it in sinc mode run the ram @ 400 4,4,4,12 then play with your fsb in 24mhz upps till you cant get it to run stable once you cant ge tit give it a little more vcore once heat is a big factor stop and go back down one setting
18 Apr 2007 at 19:31 #12 IceShock IceShock Soldato OP Joined 16 Dec 2005 Posts 4,054 Location Halifax W'Yorkshire sinc mode? btw i just tryed 3.4ghz all the way up to 1.5v and it wouldnt boot into windows. dropped it to 3.3ghz (367x9) at 1.4v it fired up 1st time. it seems stable so far so i think 1.4v might be too high. only got it at 5-5-5-18 at the moment at 367mhz ram. 1:1 its at. if i decide to stay at 3.3ghz shall i take it up to 5:4 again so its at 458mhz? thanks
18 Apr 2007 at 19:51 #13 Cupra Cupra Permabanned Joined 12 Feb 2007 Posts 8,731 Location Teesside you will find when trying to find the best overclock to leave it unsinced so if it wont boot you know its not the ram stopping you...
18 Apr 2007 at 20:14 #14 IceShock IceShock Soldato OP Joined 16 Dec 2005 Posts 4,054 Location Halifax W'Yorkshire yep i know. sorry i didnt know what you meant by "sinced"
18 Apr 2007 at 20:23 #15 IceShock IceShock Soldato OP Joined 16 Dec 2005 Posts 4,054 Location Halifax W'Yorkshire would runing 400x8 be a wise choice for 1:1 memory and it would end up at 3.2ghz, i only want 3.2ghz. or shall i run 355x9 and end up with 444 memory? thanks
18 Apr 2007 at 20:31 #16 SiriusB SiriusB Soldato Joined 16 Dec 2005 Posts 14,443 Location Manchester IceShock said: im at 3.2ghz 355x9 444mhz ram at 5-5-5-18. would my ram be able to cope at 4-4-4-12 at that mhz do you think? thanks. btw im testing it now. no errors so far, full load at 41c at the moment Click to expand... How are you cooling your CPU? Mines at 3.3GHz stable but I can't go higher as my temps are around 57C on a Scythe Ninja rev B
18 Apr 2007 at 20:42 #17 IceShock IceShock Soldato OP Joined 16 Dec 2005 Posts 4,054 Location Halifax W'Yorkshire on a 120.3 rad atm btw my overclock failed woooof thats the scareyest feeling ever when this is the best pc iv ever had i should have stayed at what it was at befor instead of being greedy lol
18 Apr 2007 at 20:54 #18 IceShock IceShock Soldato OP Joined 16 Dec 2005 Posts 4,054 Location Halifax W'Yorkshire i cant Disable Virtualization Technology its greyd out, but the thing below it the speed step i can disable that, will it be fine for clocking? i cant remember if i disabled it last time
18 Apr 2007 at 21:15 #19 Cupra Cupra Permabanned Joined 12 Feb 2007 Posts 8,731 Location Teesside speedstep slows your system down when idle... u should turn that off
18 Apr 2007 at 21:50 #20 IceShock IceShock Soldato OP Joined 16 Dec 2005 Posts 4,054 Location Halifax W'Yorkshire its off now. befor it was greyd out dont know why
