Ive been running my E6600 @ 3.15 Ghz for quite some time now, and want to take it further. It has been running at 9x 350Mhz and the ram at 875 Mhz on my DS3 all at stock volts (1.325).
I tried in the past to take it up, but it always failed at 360mhz (3.2Ghz). I tried adding +.1 to vcore, g(MCH) (Chipset?) and FSB with no results. It used to boot into Vista and then just BSOD and die. Also tried this at 370 with no luck.
Today i thought, lets lower the mutiplier and see where to go from there. Im running at 410 FSB and 8x multi at 1.4v. (So i can take it a bit further.)
So whats at fault here. I lower the multi, and can take the FSB much much higher and therefore the cpu,what can be causing this? any idea? Its quite stable (15 mins orthos) though obviously more testing is needed when i turn it up a bit faster. Ive never overclocked the ram yet, kept it as close to stock as possible (820mhz now).
Any pointers?
Any pointers?
Check your my computer properties, bet it says 3.7 or 3.69Ghz or something to that effect?
