Ok, so when I first built my PC I had really bad cooling problems, the thing was reaching like 60 on idle so I made threads and was told to reseat hs etc.... I did that and all was fine it was at what I thought was a temp I could live with... That's until I decided I was going to try and overclock it, so i looked at a few threads and I notice my CPU is actually running quite hot for the average E6600.... I ran TAT and set my cpu to 100% and temps quickly went up to 60*C... Nope that's not going to go through OCing....
During this process I was looking in my bios (my board is the intel badaxe 2) and I noticed that the smart cooling option was turned off which I thought was weird as most places suggested having it on as it's known to keep the processor slightly cooler.. So I reset my bios' settings (I hadn't really done anything so I figured I'd make sure everything was normal) and it obviously turned it on.....
I booted up my PC to try and sort a few things out and I decided to check the temp of my cpu as it should be slightly cooler.... It was at 50*C when before it had been running at 39ish..... I looked at my fan speed and it was at 800 rpm when normally it was at 1600ish...... What is going on here?
I quickly reset and turn it back off and things are back to normal..... Eh?
Do I have a problem with my board or what? :-/
I also decided to reseat my hs again, but, when trying to unplug it from the mobo I can't get it away..... I mean the wire connecting it to the board not the hs itself........ So I decide to leave it.... I'm really wondering what I should do in this situation..... :-/
Playing Half Life 2 the CPU is rising to temps of 55*C..... :-/
Basically I was wondering if anyone had any ideas of what I should do with any of these situations..... :-/
