I'm a bit worried about the temps of my E6600.
I ran a quick stress test using Everest and it reached a max of 73 deg C in a couple of minutes.
The temp at idle is mid to high 50's.
Surely this cant be right.
I'm using a Sythe Ninja (Rev2 I think) with a 120mm fan. I used Arctic Silver 5 for thermal compound and didnt use too much or too little (I dont think)
The CPU fan only spins at a max of 1215(ish) rpm. Is there any way I can speed that up?
I have 2 80mm fans drawing air in the front of the case (Lian Li PC60) and one 80mm fan at the rear blowing outwards.
The CPU fan is on the side of the heatsink blowing the air towards the rear fan.
To be honest there doesnt really seem to be much room for air to circulate freely around my case as I have a 8800GTS that could possibly be causing a wind breaker effect with the front fans.
Any help would be greatly appreciated.
