rocketman said:Hi my E6600 currently idles at 50-53 according to TAT. Is this too hot?
Also would fitting a northbridge fan be any use, and if so what one?![]()
It's an awesome controller, I have one. You get back plates with it too, which you can spray any colour to suit your case if you need to. Wires are a little fiddly but worth it. The nobs pull off with a tiny bit of force, but it doesn't damange anything. Then you can turn tiny black nobs underneath instead. The nobs, to me, look smaller than on other fan controllers.rocketman said:What are everyone's thoughts on this fan controller http://www.overclockers.co.uk/showproduct.php?prodid=OA-002-AK&tool=3 ? Also does anyone know if it'll fit in an Antec P180, the dials look quite large![]()
