E6600 heatsink & fan that comes with CPU
18 Oct 2002
Earth
Is this heatsink & fan any good to use or am i better getting another one as i was looking at a Arctic Cooling Freezer 7 Pro CPU Cooler.
But if the one that comes with E6600 does the job i won't bother.
Thanks..
Its perfectly fine if you dont want to do any over-clocking/not bothered about silence, if you are get another heat sink to replace it.
Thanks for the quick reply.
as Ender said it is fine unless you want to overclock
i would disagree about the noise though,i used it for about 3 weeks even at 100% i did not find it overly loud :)
