- 24 Feb 2007
i need help with this - im running fsb of 320 just now if i goto 325 my pc still powers up but i lose the video signal. I have pci set to 33.3 and pci-e to 101. Ive tried raising the voltage from 1.28 to 1.38 incrementing it and its the same every time. Surely i can get this processor above 3ghz atleast? im not looking to go mad and get over 3.6, 3.0ghz stable will do fine
I ran orthos and it froze after about 2 minutes too which is just fantastic. Before you think its voltage related ive tried it on default and increments up to 1.35, and its not overheating, stays around 45c.
Now i might just be doing something stupid cause i havent overclocked before but any advise would be useful about now, this system apparently should have brilliant overclocking ability but i cant seem to get anything out of it. Even the memory wont run at its correct level (4-4-4-15) and runs at 5-6-5-15, if i change that it blue screens when loading too.
full system spec is:
e6600 core2duo currently @ 2.8ghz 320FSB (although orthos is freezing so that might go down..)
p5b deluxe motherboard
8800 GTX 768mb graphics card
corsair 620w PSU
2x 1gb OCZ PC6400memory currently at 800mhz with 5-6-5-15 or something high like that
2x seagate baracuda 7200.10 320gb drives in raid 0
1x seagate caviar aaks 500gb hdd
1x western digital 250gb hdd
standard sony dvdrw
tuniq120 cooler - used thermal paste supplied with this
lian-li pc7 plus case with intake/exhaust 120mm
floppy drive with media card reader
corsair 620w PSU
standard sony dvdrw
)look in cpuz at vcore and see for youself
