- 1 Jun 2010
- Bedford
Hi guys
I posted before on this issue but would like some more help please. Basically I am overclocking E6600 on Gigabyte ep45 ud3lr. I managed to overclock E6600 to 3.0GHz on stock voltage 1.3250V (VID) and it ran small FFTs in SP2004 Orthos perfectly. However I wanted to overclock more to 3.4GHz so this is currently what I get:
- [email protected] (346MHz X 9) CPU Vcore = 1.33750V (stable value)
- [email protected] (356MHz X 9) CPU Vcore = 1.35625V (stable value)
- [email protected] (367MHz X 9) CPU Vcore = 1.39375V (currently not stable)
It seems I am facing law of diminishing returns where for a constant FSB increase of 10-11 MHz I am inputting more voltage
. The CPu Vcore increases in increments of 0.00625V. So my next value is going to 1.39375+0.00625V = 1.40V.
If E6600@ 3.30GHz passes 30mins Orthos test at 1.40V it would seem quite a lot for 3.30GHz. I have a feeling that to reach 3.4GHz I could end up increasing CPU Vcore to 1.48V.
I have checked intel website and VID range seems to be 0.8500-1.5V. This means I could end up getting dangerously close to max value. Also during overclocking I had mobo power saving feature on. Would this have any effect on the CPU voltage consumption or should I disable it? Also do I need to increase any other voltage? How are people able to reach 3.6GHz and beyond on this CPU and my mobo is supposed to be a good overclocker. So I would really appreciate advice please. Thanks.
. The CPu Vcore increases in increments of 0.00625V. So my next value is going to 1.39375+0.00625V = 1.40V.If E6600@ 3.30GHz passes 30mins Orthos test at 1.40V it would seem quite a lot for 3.30GHz. I have a feeling that to reach 3.4GHz I could end up increasing CPU Vcore to 1.48V.
. Would the board happen to be Gigabyte P35-DS3? Also should I go back to 3.2 GHz and just up the VCore by one notch to be on the safe side in terms of stability. Would I notice much difference in the performance of game such as Crysis between 3.2GHz and 3.4GHz?
