Hi,
bought this PC at the weekend and have been looking at overclocking it a little. Finally got to my target of 3GHz last night prime stable for 4 hours using the following settings
337.5 * 9 (based on 3:2 ratio with memory running at 900mhz 4-4-4-12-2t)
Vcore = 1.328v from CPUZ
Ram = 2.1v
The system i have is
Thermaltake Soprano Case (2*120mm fans)
BFG 680sli mobo
E6600
Geforce 8600GTS
2 Gig Geil ULL Ram
Scythe ninja with 120mm fan
Thermaltake 700W PSU
Vista Basic 64bit
now my temps when idle are between 41-44 and after 4 hours of prime 57-59 on load.
The temps although not overly high are worrying me in terms of pushing this further. I tried 400*8 last night to get 3200 in sync mode with the FSB at 1600 and memory at 800mhz however i was getting temps up to 66 in prime after 20 mins before my pc restarted, that was running at 1.36V and therefore would have needed higher to get it stable meaning probalbly hiogher temps.
So I've settled with what i have for the minute however have you got any tips on what to do next ?
My thoughts are to basically look at the cooling to start with, having read reviews on this cooler etc it doesnt seem to bad however from what i can gather the stock 120mm fan isnt the greatest. Same with the Case the 2 stock fans although quiet are not great in terms of airflow. I have been thinking of replacing all three with
http://www.overclockers.co.uk/showproduct.php?prodid=FG-037-AK&groupid=701&catid=57&subcat=4
the Akasa ultra quiet 120mm fan for the front and Rear
and the
Xilence XPF120R Red Wing 120mm Quiet Fan
http://www.overclockers.co.uk/showproduct.php?prodid=FG-000-XI&groupid=701&catid=57&subcat=4
for the heatsink, this should give me much better airflow into the case and also a the CPU fan will produce 20CFM more per the specs which should hopefully lower the temps significantly.
I am happy with this overclock but want to see what if anything more i can get out of it but without increasing tems beyond 60degrees, if anyone has any tips / tricks or ideas please feel free to post !
PS1: this system got 10046 in 3Dmark 2005 at with that cpu overclock and 8600 at stock is that about right ?
PS2: What are considered safe temps and voltages for this chip ?
Ram = 2.1v
BFG 680sli mobo
E6600
Geforce 8600GTS
2 Gig Geil ULL Ram
Vista Basic 64bit
and the
