- 8 Jan 2007
I am running my c2d E6600 water cooled and the idle temps are 45-50c and under load about 65-68c does this seem a little high to you guys on water.
SHREDDER1UK said:I am running my c2d E6600 water cooled and the idle temps are 45-50c and under load about 65-68c does this seem a little high to you guys on water.
marscay said:high end water and a lapped e6600 with low volts gets you these temps under load.....and no lying![]()
GreenThu)v(b said:I can see this being a massive problem once summer hits, specialy if we have heatwaves like last years!
WJA96 said:What temps do you get after an hour of Gromacs or an hour of small FFTs? I can do Blend at 53C, but Gromacs gets me up to 10C more!
WJA96 said:Don't you just knock the overclock down to stock?
GreenThu)v(b said:im running a V lower than default. Even with 2.4ghz. I will still get the same sort of temps.
The Laughing Ma said:Why does everyone use Orthos instead of TATs CPU loading tool? Whenever I run Orthos I always get lower load temps than I get when I do 100% on both cores with TAT.
marscay said:with great airflow in my case time is irrelevant really, small FFT's load at 45-46c max with just 3 yate loons on my PA120.3 ...if i turn my 97cfm xinruilians as well you can take another 3-4c off this figure....high fft's generally sit a few degrees lower than small.
of course with the window open and a nice breeze i can prime/orthos small FFT below 40c easily with just the 3 yate's....get's a touch cold in the room tho![]()
i've never used gromacs.
WJA96 said:Well, I could put two deltas on my radiators, turn the aircon down to 12C and it would run cooler, but it would be intolerable. Under normal room temperature conditions using the same fans and speeds as the ones in the original screenshot what does the Orthos Gromacs test show once the temperature stabilizes? I've just noticed that Small FFTs and Gromacs run higher on my system and I was interested in what it did on yours.
Like you, my system stabilizes after a couple of minutes, but even so, the temperature differences can be see clearly;
That's why I asked about what happens on your system with Gromacs and Small FFTs - Blend doesn't seem to give me the highest thermal stress on the cooling system. Small FFTs does.
