Hi , ive had my e6600 for well over a year now and had it clocked to 3.2ghz from day one , its in a gigabyte DS3P mobo cooled by Noctua NH-UF12
the problem srarted earlier this week , the mobo has one of the dual bios setups , so on the odd occasion the pc would fail to boot the seconadary bios would kick in and revert all bios settings back to defaultand the machine would boot now usually id just go back into the bios reset up my overclocks and that would be done
But now when i try to achieve the overclocks they simply wont stick , the dual bios kicks in every time and resets every thing ?
ive cleaned all the cooling fans (3x120mm) and cleaned the dust of the noctua fins but still no joy , now the CPU will run happily at its default 2.4ghz , so dont know what to think
is the CPU on its way out ? mobo maybe ? CPU just needs extra volts suddenly (1.4v atm) ?
any ideas guys ?
any ideas guys ?
