I thought this would be easy
E6600 @ 3.2ghz
2GB OCZ Platinum @ 400mhz 5-5-5-15(spd)
650w Coolermaster extreme
P5B Deluxe @ 400mhz FSB
If I run Prime95 it errors after a while.. somtimes 1-2 mins sometimes 1-2 hours, seems fine with everything at stock (as I would expect), temps seem ok at 3.2ghz (55-60 max in TAT), I have raised voltage a little 1.28-1.32v, still no joy, I really dont know what could be causing this.. I thought this was quite a conserative overclock?.
Any ideas or is it just a case of slowly raising FSB etc.. I'm not sure but CPU-Z says this P5B is "revision C1" is that the older one?.
.E6600 @ 3.2ghz
