Idiot warning.
I have a E6700 overclocked to 3.4. Voltage 1.41
It is in a TJ07 with all 6 fans replaced with Ambers and a Zalman 9500.
A P5W DH MB Geil RAM 800 HZ. 7600GT
All new kit which was my first complete new build.
Not happy with my first overclocking attempts or the temperature of the CPU which I am assuming is limiting me.
Core temp is reporting 52 and under load up to 68. Stable.
Why? I am going to have to reduce the clock. At standard settings idle temp was 48 - still hot.
Air out of the exhausts is not hot. Air pushed out through the Zaman is not hot. The heat pipes are not hot to the touch nor are the North or South Bridges and yes I have taken the clear protective wrappings off.
I have reseated the Zalman so the air blows up to the exhaust fan. The Thermal paste is fine (in my view). I used a pea sized amount and spread it. All the fans seem OK.
MB temp reported by ASUS probe is 42.
I am certain I have the ambers either intaking or exhausting correctly.
Other than reseating the Zalman yet again - any ideas what I am doing wrong?
