E6750 Fan needed
12 Dec 2005
Hi guys,
I don't know much about cooling/fans etc but I want a new fan for my E6750 as the current one is quite naff.
Could you point me in the right direction please?
Cheers
Didnt know your budget so Started at £20 and worked all the way to £70, I would go with the h50 but thats just a sealed water unit.
Also didnt know if you overclocked, wanted silent etc.....
Anyway all the links below are good right up to the best (dont sell silver arrow!!)
Bang for buck I would go with the Thermalright IFX-14
http://www.overclockers.co.uk/showproduct.php?prodid=HS-035-AR&groupid=701&catid=57&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=HS-069-TR&groupid=701&catid=57&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=HS-005-PL&groupid=701&catid=57&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=HS-011-NC&groupid=701&catid=57&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=WC-002-CS&groupid=701&catid=57&subcat=
Thanks for the reply. To be honest I didn't expect to have to spend £20. I wont be overclocking, just gaming so only needed something to do the trick.
You get what you pay for... Do you want something that 'does the trick' or something that does the trick really well?
+1 for the IFX-14 - that's what I'm planning on getting on mine sometime soon :)
Just spotted OP is getting a stock cooler for just postage costs in the Members market, so thats even better value then the artic lol. And will still do the job nicely
