Cob said:Look up 'patience' in the OED.
Im looking at that chip, what speed you getting out of it?PCZ said:Running an E6750 in a P5N-E SLI board here.
Bios recognizes the chip OK. (0608)
Sets 333mhz FSB automatically.
Runs great
Only slight problem is the default vcore is set too high on auto.
You can set it to the correct voltage manually though.
This will probably be fixed on the next bios update.
I am very happy with the combination of the P5N-E SLI and the E6750.
Fast. Cheap and overclocks well.
Tuvoc said:The P5N-E SLi DOES support 1333 CPUs. It is in the release notes for BIOS 608
For some reason ASUS have missed it off the section where they list the 1333 mobos
And look here, it says:
Support Intel® next generation 45nm Multi-core CPU
http://www.asus.com/products.aspx?l1=3&l2=11&l3=473
Wiggins said:Excellent![]()
I was looking to maybe update my 650i board in the next 6 months but if its going to support 45nm cpu's then I may as well wait![]()
Cob said:Yea but I doubt the 3 phase (and possibly the 4 phase) boards will be any use for overclocking the 45nm chips.
