E6850 Overclock on air what will it reach ?
18 Feb 2006
Halifax
HI
Could you please tell me what the E6850 will oc to on air, an example of this was the E6660 all i had to do was change the fsb to 333 and I could hit 3Ghz
Now what speed would it run at with only a FSB change
thanks for taking the time to reply, system spec below if required
My Spec
Intel Core 2 Duo E6850 "LGA775 Conroe" 3.00GHz (1333FSB)
Zalman CNPS9700-LED CPU Cooler
Asus P5N32-E SLi nForce 680 (Socket 775) PCI-Express DDR2 Motherboard
OCZ 2GB (4 x 1GB) PC2-8500 1066MHz Reaper HPC Edition Dual Channel DDR2
BFG GeForce 8800 GTX OC 768MB GDDR3 HDTV/Dual DVI (PCI-Express)
2 x Seagate Barracuda 7200.10 500GB ST3500630AS SATA-II 16MB Cache RAID 0
Western Digital Raptor 150GB WD1500ADFD 10,000RPM SATA 16MB Cache
Corsair HX 620W ATX2.2 Modular SLI Compliant PSU
Antec P180 Advanced Super Midi Tower Case
Dell Ultrasharp 2407WFP 24" Widescreen LCD Monitor
Razer Tarantula Advanced Gaming Keyboard
Razer Diamondback
Vista Ultimate 64bit
2 x Noctua NF-S12 800RPM 120mm Silent Case Fan - 3 Pin
3 x Antec 120mm Silent case Fans
Netgear DG834N 270Mbps RangeMax NEXT Wireless ADSL2+ Modem/Router
Netgear GS605 5-Port Gigabit Desktop Switch
Synology Disk Station DS107+ Plus 1 Bay SATA NAS Server
Seagate Barracuda 7200.10 500GB ST3500630AS SATA-II 16MB Cache (Fitted to the NAS)
4GHZ should be easy, if cooling and other parts can cope with FSB rise.
Take it in stages slowly but 425 FSB (1700mhz) will get you to 3.825 GHZ
The mobos has a volts droop, there is a pencil mod avail for it though, I have same layout on a Striker E.
