- 25 Mar 2010
- Falkirk
I have clocked my kids cpu to 3.6ghz(e6850) which is stable but hitting 67 degree on cpu under load using OCCT, the cores are on average 10degree higher,most likely due to the £5 quid cooler on there. My kids Pc is used only for gaming, it has a HD4850 1gb card.
My question is under real usage while gaming does a cpu hit 100% consistently that those temps would maybe be a problem.
Thanks
Thanks
