E7200 Stock HSF overclock
7 Jul 2008
ello
I've read the guides a number oif times, and it all looks too complicated for me.
Does anyone know the perfect voltage/speed (ghz) for E7200 on Gigabtye P35-S3L using stock cooling. also will I need to change memory timings for Corsair 4GB Kit (2x2GB) DDR2 800MHz/PC2-6400 XMS2 Memory Non-ECC Unbuffered CL5(5-5-5-18) Heat Spreader.
If so can someone give this info to me, I'll change it in BIOS and hope it works.
Thanks
My e7200 does 3Ghz on 1.1125v easily and is 8 hours prime stable, it normally tops out at around 46'/43' on each core, this is with a TRUE though so i would expect your temps to be in the 60's.
FSB = 312
Multi = 9.5
Pci frq = 101
Timings = 5-5-5-18
VID = 1.1325
Vcore = 1.1125
Memory voltage = 1.9
