- 22 Apr 2009
Hi everyone
I have been following this forum on and off for several years and finally decided to sign up. I have just built a new system after running an overclocked X2 3800 socket 939 for 3 years.
My new spec is as follows:
Core 2 duo E7400 (2.8ghz stock) with Freezer 7 Pro Cooler
Asus P5Q Pro
4 gb Corsair xms6400 (rated 800mhz)
Antec 300 case with 2 120mm Xilence Redwing fans in front, and stock rear and top fans running on lowest speed settings
Sapphire Radeon 4850 with modified cooling
Thermaltake TR2 RX 550w PSU
Vista 32 bit
I have overclocked so far to 3.7 ghz (370 x 10; 1.36 vcore in cpu-z) but would like to go further. Running Prime at the moment and coretemp shows temps as 72 degrees c on each core fully loaded (after approx 45 mins running). Does this sound about right, as obviously this kind of loading represents an extreme situation not replicated in day to day gaming etc.
Alos, what kind of voltage should i be looking for to get to the magic 4ghz, and would a higher FSB have more impact on performance than a higher multiplier @ 4ghz (for example, a lower multiplier and higher fsb; or higher multiplier and lower fsb)?
Cheers
Asus P5Q Pro
Vista 32 bit
Cheers
