E7500 Always Same Temps
15 Feb 2008
Have just built a small file server using freenas and have noticed that the temperatures for both cores seem to be stuck at 51°. When checked in BIOS they are around 31° to 34°.
Should i be worried about this or am i fussing over nothing?
Every 45nm Intel cpu i have had has had stuck sensors to one extent or another. Usually all have been stuck but my Q9550 only has one core stuck. When it goes over the temp it's stuck at there will be movement. There is no fix.
ah well, got it for a cheap price so can't complain too much :D
