e8200 and CPUz
22 Jan 2004
Hi,
Just recently purchased an e8200 and Asus P5k, and Corsair 6400.
Whatever verions of CPUz i use it says the CPU multiplier is 6.
How can i check if this is a software error or my CPU is using 6?
Are there any other programs i can use?
Thanks
You have speed step enabled, run a stress test programme or an apllication you should see you multiplier rise, not sure what the default multiplier is.
Edit: The multiplier should raise to 8, if it does not check your BIOS it may of defaulted to 6.
Rob
