e8200 temps too high?
Caporegime
29 Jul 2011
In acme's chair.
Im running an e8200 under the intel stock cooler (with the larger heatsink, the one supplied originally with the e8200) with arctic silver 5 (applied 3 days ago) and it is sitting at 40*C idle, and it soared up to 84*C on prime95 blend!
Stock clocks and volts as well
Isnt this too high? I thought the maximum safe temp was 72.4 for these chips?
Using HW Monitor to get temps.
I'm convinced that this is totally wrong though, if i touch my hand to the heatsink while HW Monitor is reading 84*C, it feels cold, and the air coming off of the cooler also feels cold.
I am pretty sure that the cooler is mounted properly because the TIM spread evenly when i fitted the heatsink, and there is definite contact between the heatsink and the CPU. The push pins are all in fully, and in the locked position also.
Could this be a problem with HWMonitor or the onboard temperature sensors?
Can you suggest another program i could use?
I am going to try coretemp in a second.
Coretemp gives the same readings.
Reseated the CPU cooler, readings appear the same. Thermal paste hasnt cured at all yet, still gloopy in consitency.
I replaced the push-pins on the CPU cooler before i fitted it as the old ones were broken.
The ones i used were off of a cooler supplied with my socket 1155 i5 2500k, but they appeared to be identical. The i5 stock cooler did not make contact with the CPU, hence why i had to fix the socket 775 one instead... I was under the impression that the intel stock coolers were supposed to be universal?
*update*
I re-seated the cooler again, and this time noticed that the push pins were not quite twisted far enough around (litterally a tiny bit more movement, hardly noticeable) was achieved when i put some effort into twisting them a little more (didnt have a screwdriver to hand)
Idle is now 39*C, load on prime so far (after 5 minutes) is 51*C
/close
