E8200 with stock cooler, too hot?
18 Nov 2003
hi guys just installed e8200 with stock cooler, but temps seem to be high.
installing cod4 it was around 58*C , is this too hot?
I did have a fight with installing cooler, it did look like intel needed to put bit more paste on sink.
cheers
well i dont think so. its running on ga-p31-ds3l
i did have a problem with cpu_fan header (the fan stopped) so i switched it to case_fan1
doing a RMA for cpu header seems to be a bother but if i need to i will.
i think it was running at 1700RPM in bios, is this slow?
Processor E8200 2.66GHz- Thermal Specification: 72.4°C limit, so 58°C should be ok for stock speed. If you plan to overclock a aftermarket cooler would be advisable- Arctic Cooling Freezer 7 Pro CPU Cooler.
ok i just turned the new pc on and i'm getting like 45*C cpu1 52*C cpu2 idle....that why speed step
do maybe i need to resit sink? 1700RPM normal or should it be more?
cheers
If your getting higher numbers when re-applying the heatsink theres a pretty good chance your doing something wrong. Made sure you clicked in the heatsink properly ? It requires a little force.
yh i did something wrong, after it clicked in i turned it (the pins) now re seated and AS5 is on after i cleaned with tissue and water...(dont ask LOL)
its better. Happy with the system.
Thanks
