- 14 Nov 2006
very stable, running now over two weeks
I still need to majorly OC mine, I've had it running at 3105 mhz I think.. but It still seems like a rocket ship compared to my X2 4400 which was @ 2805 Mhz,
I can't seem to find a damn thing about Overclocking Core 2 Duo chips !!
Can someone please explain the following to me.
Back when I overclocked my SK939 chip, you would up the FSB which would then inturn raise the RAM speed and HTT speed, so you adjusted the multiplier on the HTT so it wouldn't top 1000 and dropped ram down or left it ( if you wanted to oc It )
with my C2D , I can't seem the find any reference to the HTT ? does it not exist ?
and I'm unsure how far my ram will go, its the 2GB Crucial PC2-6400 Cas 4 with the DHX aluminium heatsink things ,
Thanks in advance.. and OP.. lovely clock![]()
HTT is an AMD only thing, the Intel equivalent is the FSB which is quad pumped e.g. my E8200 runs @ 2.66GHz at stock (333MHz x 8) so the FSB is 1,333MHz (333MHz x4). From what I can tell so far, the overall FSB doesn't mean a great deal, you don't need to keep it under a certain speend like you did when overclocking AMD CPUs.
I'm pretty sure there's a sticky about novice overclocking at the top of this forum.
