- 30 Jan 2008
Hi folks - been reading all the excellent advice on the board but as this is my first time overclocking I thought I'd check with you all first
I've bought and installed the following:
E8400
Abit IP35 Pro
4Gb (4 x 1Gb) OCZ Platinum 6400 DDR2 RAM
Sat in the Antec 900 case OCUK like to sell all their p.c.'s in. I've added the side panel fan to help cool the 8800GTX (and cpu as an aside). 600 WATT brand name PSU
Core Temp shows the CPU running at approx 40C on both cores, so the stock cooler is going... no surprise there. CPU-Z shows 1.140 Volts on the CPU
I had issues with getting anything working at all first until it dawned upon me that the auto settings on the RAM set the voltage to 1.8v!! Upped to 1.9 and all is working fine now.
I upgraded the BIOS to v16 beta in an attempt to fix the start up issues and it's running fine.
What I'd like is to have the E8400 running at 4GHz (ideally) and I've read through the beginners guide (well written and thanks), so I know I need to up the voltages on the CPU and memory then start stepping up the FSB speed... oh and loosen the timings on the memory (5-5-5-15 I think someone said. I have it set manually to 4-4-4-15 at the moment)
So do I set the voltage on the core to 1.3V ish and the memory to 2.0V and go from there?
Could someone recommend a cooler from OCUK (I'm 20 minutes from the shop) and possibly just say - "set the BIOS to:" and save me some time
Thanks folks - I have looked for a similar post but you guys know the details of OC'ing and while I am PC techie (security & Server side) the black art of overclocking has been an unknown to me
(so quite a lot that is said assumes a fair degree of previous knowledge)
E8400
Abit IP35 Pro
