E8400 Bottleneck a Higher End Card?
24 Nov 2011
Howdy!
I've got the upgrade bug once again, but rather than build an entirely new system, I was hoping I could just go with a new GPU (maybe a 670 or 7950). Anyway, would my E8400 @ 3.6GHz be a huge bottleneck with 1080p gaming, bearing in mind I have a 3D monitor? Or would I indeed be better off starting a new build from scratch?
Thanks for any advice/feedback!
I think you would be better off upgrading your platform.
300 quid will get you a decent cpu, motherboard and ram.
Don't do what I did and flog a dead horse, I changed from E8400 to Q9550 even though the i5/i7 were out (I wasted money imo).
Thanks, guess I'm just looking to be miserly!!
List your system spec
Thanks for the reply. Spec is;
E8400 @ 3.6GHz
Asus P5K Pro
Sapphire HD4870
Corsair HX620
WD 640AAKS Hard Drive
Samsung S23A700D monitor (1920 x 1080 @ 120Hz).
Thanks. Most helpful!
Long story short, yes it will bottleneck in some games but generally you will see a massive improvement over a 560ti or 5XXXX style older GPU.
When I went from E8400 stock 3.0GHz with 8800GT to GTX460 I got a decent FPS increase. However when I went to i5 2500k initially not overclocked I got a big boost too.
