e8400 + p5q-pro help
18 Sep 2008
Hey all got a OC problem I would like some feed back on
I have 4gb of OCZ ddr2 800mhz ram
With this mother board I cant manually change the FSB:DRAM
Its got 9* multi on it so to get 4ghz (that i want) i need 445*9, the problem here is that that makes my ram try to run at 1:1 at 890mhz. Is there any way to counter this or should i pick up some 1066 ram?
Cheers in advance
Unfortunately Intel chipsets don't allow mem dividers lower than 1:1. With any luck that OCZ kit should be able to do 890mhz, try loosen up the timings and increase the DRAM voltage a little.
hmm ok the timmings i tried was 5 5 5 15 and its at 2.2 volts atm, though in cpuz it says its on 2 which is weird
It used to be at 4ghz stable but then i went from vista 32- 64 and i cant get it again, maybey this clue can help
