E8400 reporting slower speed
13 Jun 2004
Brechin
AS mentioned, just installed my new cpu from my old E6600, which was 2.4ghz and this E8400 is reporting as 2.4ghz as well should i have changed anything in my bios? i updated my Bios to a newer version as the asus website said that it supported the cpu on *** newer bios
yep speedstepping options in the bios
also i heard something about vista being able to interfere too (power/performance settings), but i see your using xp pro
Think ive sorted it, went into some part of my bios and instead of doing a manual config, like changing the ram voltage to 2.1V ( which i read its meant to be) i switched it all to auto, now its reporting at 3ghz, but will see if its the same when i switch of my system tonight and back on tomorrow.
