E8600 info
mine is running at 22c right now, but only have a few apps open currently , nothing major. when i run far cry 2 benchmark goes up to 25c.
asus probe sucks - lol, just checked temps with core temp and speedfan and my temps are 38 on both cores right now
PS: as long as you are below 65 on load, you are ok.
I thought your temps seemed low :p - at the moment got my chip at 4.4 and idle is 40c full load around 50 -52c
At stock my temp sensors are stuck :rolleyes: soon as I overclocked they moved when stressed.
i am surprised by my temps actually, coz with my e6600 oc @3.3 i was at 39c idle with a zalman 9500 cooler. doesnt seem that e8600 is much cooler, then again my noctua cpu cooler is running at 900rpm for noise reduction, i can always crank it up to 1200rpm if i ever feel the need to oc the e8600
22C is amazing. What sort of room temperature if I may ask?
Also, is it as fast as the [email protected]?
I am thinking rather than overclocking my Q6600 to 3.0GHz to obtain the same performance of a E8600 out of the box, I would rather upgrade my Q6600.
Despite I have just bought this who rig weeks ago...
It's never going to be a set temp. There are so many variables. Clocked or not. Voltage. Cooling type. Case type. Location. One thing is for sure though. It will be cooler than a Q6600.
Personally i do not think the E8600 is a good buy. The more sensible option is to go for a E8400. All will hit 4Ghz more or less.
Most e8600 have stuck sensors from what I read and also intel said anything under 45 - 50 is more than likely incorrect by a few degrees either way. Also you need to use latest core temp or real temp to get correct temps for wolfdales.
At stock my E8600 idles at 33/33. Under 100% load it gets to 52/54.
Surprisingly enough I get the same temps overclocked at 4.3 ghz
C2D E8600 @ 4.3 ghz
GA-EP45-UD3P
HIS 4870X2 2GB
4 GB Corsair Dominator 1066 mhz 5-5-5-15 (2x2GB)
Noctua NH-U12P
Corsair TX 650
Samsung SM-2443BW 24" Widescreen LCD 1920x1200
