E90 330D Buying advice
  • Thread starter Thread starter Sam
  • Start date Start date
Sam
Sam
12 Jan 2003
Surrey
Hi Chaps
Looking at replacing my E46 330D which I've had for the last year, its been fantastic and done everything needed however i fancy an E92. I'm looking for a 330D Msport however I'm also considering a 325D Msport and if a decent 335D came up id also consider this. I currently do around 25 - 30K per year so really want to keep to a diesel.
Anything to look out for on the E92, any particular options that I shouldn't miss?. Bluetooth and Pro nav is a must for me.
Budget cap is around 16 - 17K
Thanks in advance
Sam
Haven't looked for a while, but would that budget get you CIC idrive?
I think at a push, that's what a 08 > 58 Car. Would probably get a 325D. Is the newer Idrive that much of an improvement though to warrant excluding cars with the older variant?
i thought you wanted an e92?
The newer idrive is signficantly better and you might just sneak one in, but at this budget i wouldnt be too bothered about it
[TW]Fox;22898905 said:
Spending that much on an e90 is bonkers. Keep your e46 another year then buy an F30.
I absolutly agree.
I threw 11 grand at my E90 07 330i. I was lucky to realise that it was a heap of crap after my E46 and sold it for 11,250 6 months later.
( The E90 had every extra possible, so it wasn't the spec that got me down, it was the build quality and the money I had paid for it for something essentially that was lesser quality.)
Perhaps I'm getting confused
When did the E92 come in, is that just a facelift E90?
Sam
you have the same thoughts on a E92?
I absolutly agree.
It's the coupe.
Ahhh im getting in a muddle, I'm after an E92 :)
Given that you're looking at pre-ED diesels with the assoicated fuel economy, have you noticed the combined figure of the 325i/330i?
Are you specifically after an auto, or would a manual be considered?
E90, E91,E92, it's all the same plastic rattley crap.
Really?? Mine seems quite nice :p
Not plastic or rattley yet :D
Given that you're looking at pre-ED diesels with the associated fuel economy, have you noticed the combined figure of the 325i/330i?
Did the ED diesels come in after 58? Surely the difference is marginal :confused:
Ideally id prefer a manual however i heard the autos are pretty good :)
[TW]Fox;22899746 said:
Pretty much, yea, though they don't like quite as old as the pre facelift E90's do now. As you know I had an E92 for a bit last year.
30k a year in an E92? Why would you do that :(
I find my E46 330D luxurious :p must be all those other cars ;)
what would you suggest for around 16k?
Sam
I couldn't imagine spending over 10k on an e9x with the (reportedly far superior) f30 out now. Can you wait a while and get a decent f30 for similar money?
Hasn’t the F30 only just been released, surely i would be waiting another year for them to lose some value?
It's not really that long in the scheme of things :p.
It's that awkward phase in the model cycle where the latest model is too new to be in budget but a good example of the older model is too expensive to justify.
