Koss KSC-75. I don't think anything in the sub £20 area can match it from a sound point of view. To me, it compares favorably to £100-ish IEMs if isolation is not part of the equation.
If it HAS to be in-ear, non IEM, then the Sennheiser MX500.
If it HAS to be IEM, then the Creative EP-630 is getting a lot of prop.
both of those earphones look good, ill prob end up gettin them on the bay as theyre cheaper, plus the bay aint bad for products like these, they costa round £10
not so sure if i like da creative one, the texture of the rubber earpieces might annoy me
the creative Ep 630s are excellent earphones for there price. so good that 3 companies make the same earphones creative, seinheisser and razer all do these earphones in different names. my ep 630's can almost compete against my shure ec2's
i use Sony MDR-EX71SLB for my mp3 player and they are excellent. they are canal ear phones and block majority of the bacground noise. Because they go right inside your ear and create a kind of seal the bass is amazing. they come with 3 different sizes of ear plugs for the perfect fit. would definately recommend them.
