Summary: I would like to know of a good way to earth yourself when working on ESD sensitive components in a "home enviroment"
Hello People! I am currenly at a stage where I am comfertable with building my own PC. But for about 6 months I have been messing around with second hand stuff. To earth myself. I set myself up at a table next to a radiator (painted, I dont think this should affect earthing) take a seat tough the radiator and commece work. Touching the radiator at about 30 second intervells (I dont think this is needed but I was just "playing safe".
My question is this... what is the best way to earth yourself in a "home enviroment" where access to an earthing station or specialist equptment is not available. I have heard that if you plug in a PC to power outlet, turn off the swtch on the wall or the back of the PC if poss on the PSU, pressing the power or reset switch a few times to drain all electricity from the components, touch an unpainted surface of the case and there is the earth (human - case - psu - power lead - earth @ power point). I think this should work. What do you all think.
All advise and comments are welcome with appreciation.
NO,NO,NO
