Easiest way to monitor precise tower temp?
25 Oct 2008
Hi, I know a hand by the fan is obvious answer, but is there a option in system tools I've missed which shows real time temp in the case?
Its christmas, everyone is with family :P You can find out the temps of individual components such as CPU/GPU/HDD and the motherboard by using an app called everest ultimate. There are also lots of different apps that will do this but I prefer this one. If you boot in to your bios, that will also tell you the CPU and motherboard temperature.
