*** Easter Weekend Deals *** Cases Round
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Aerocool Syclone II Midi Tower Case - Black/Red @ £59.99 inc VAT
The Syclone II is solidly constructed in 0.6mm SECC Japanese steel and beautifully finished both inside and out. Not only is the chassis beautifully finished in all black (both interior and exterior), the PCI covers, motherboard tray, removable HDD cage and screw-less kits are high-lighted in blue or red. This makes the case look unique, helping it stand out from the others. The combination of colours, glossy front panel and the front LEDs give the Syclone II case a striking appearance.
The Syclone II case has been designed to be user friendly with its great expandability and versatility. The screw-less feature and pre-drilled holes on the motherboard tray for cable routing make this chassis a joy to work with. The pre-drilled cable routing holes are also protected by high quality rubber to prevent cable damages from sharp edges. A CPU cut-out is also pre-drilled on the motherboard tray for ease of CPU cooler installation and removal.
This chassis offers plenty of space for installation of components. Behind the front door are four 5.25" drive bays with one of them having an adaptor to allow for a 3.5"device to be installed. Inside the chassis are six 3.5" drive bays that are ideal for 3.5 or 2.5" HDD/SSDs. The chassis is deep enough to accommodate long graphics cards up to 400mm in length (when the middle HDD cage is removed). With the middle HDD cage installed, the chassis can support cards up to 290mm.
To keep temperatures down there are three locations for installing case fans. At the front of the case there is a 140mm LED fan (supplied). This brings cool air into the case and helps to aid HDD cooling. At the rear of the case is a 120mm LED fan (supplied) which extracts the warm air from inside the chassis. Finally the side panel also has room for a 120mm or 140mm fan (not supplied). This fan can be used as an exhaust or an intake fan.
The Syclone II is certainly a case that will catch other people's attention, with its aggressive looks and the stylish colour co-ordination. In AeroCool's words, it is the "ultimate eye catcher".
- Chassis Dimensions: 480(H) x 270(W) x 525(D)
- Material: SECC 0.6mm Japanese Steel
- Motherboards: ATX & Micro ATX
- Drive Bays: 4 x 5.25" (external) / 6 x 3.5" (internal)
- Expansion Slots: 7 Slots
- Max length space available for PCI slots: 280/400 mm
- I/O Ports: 2x USB2.0 / e-SATA / Mic and Headphone
- Cooling Options: Front 1x 140mm fan (supplied), Back 1x 120mm LED fan (supplied), Side 1x 120/140mm fan (not supplied)
- 140mm Fan Specs: 1500 RPM, 96.5 CFM, 1.069 mm-H2O, 29.6 dBA
- 120mm Fan Specs: 1500 RPM, 82.6 CFM, 1.273 mm-H2O, 26.5 dBA
Was £67.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Aerocool Xpredator X3 Gaming Tower Case - White/Black @ £79.99 inc VAT
Although it is smaller in size compared to the original XPredator, this chassis is still wide enough to accommodate a 20cm LED fan at the front panel. On the top panel, just like its predecessor, two fan controller knobs each can support up to 25W, far more advanced than the original one of only 10W per channel. Inside the chassis, you can mount up to 8 HDDs and there are 8 expansion slots plus a 310mm depth for high-end graphic cards installation. Both X1 and X3 are designed to look "within the family" - the scale-like ventilation on the top panel can be opened and closed for better air flow regulation - its distinct feature that can be seen in all XPredators.
- Solidly constructed chassis interior (0.7mm SPCC).
- Supports CPU cooler max. height up to 186mm(without fans on side panel).
- Supports Long VGA Cards up to 310mm.
- Includes 1 x 14cm Black fan at rear and 1 x 20cm LED fan in front.
- Top panel flaps can be opened or closed to control air flow more efficiently. Dust filter for PSU .
- Includes 1 x external 2.5" HDD docking on top panel for easy access.
- Includes two fan controller knobs each controls fan/s up to 25W.
- Install up to 9 fans!
- Includes antivibration pads for HDDs and PSU.
- Cable Routing Management holes with high-end rubber grommets to protect your cables.
- 2 x USB3.0 or 2 x USB2.0 and Audio/Mic ports are easily accessible from top panel.
- Pre-drilled CPU holes for easy mounting and removable of CPU cooler.
- Support water cooling.
- 2 x USB3.0 and Audio/Mic ports are easily accessible from top panel.
- USB3.0 >USB2.0 adaptor included.
Was £86.99 Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
Anidees AI-6BW Midi Tower Windowed Case - Black @ £109.99 inc VAT
nonl2br
<p>The AI-6 gives an immediately clear first impression of quality and elegance. The Front cover shows a fairly large unit which houses a plastic exterior and with a brushed aluminum centre. In between lie, a set of stealthy, and concealed air vents, which should ensure good cooling.</p>
<p>This look is made possible through a closed front door, which is open when delivered to the left, this can be switched by the user to the right if required. If you open it, one sees a rectangular mesh field in the lower and upper area. The drive bays are provided by three 5.25-inch apertures. For each of them they can be cut away in order to push through an external 3.5-inch device.</p>
<p>Although only an adapter factory setting of one of three 5.25-inch slots at Al-6 is, but those frames can be conveniently buy more if needed. The lid of the clear line is continued by the I/O panel which is inserted inconspicuously. Two USB 3.0 ports that are present in addition to audio connectors and four USB 2.0 and are connected internally.</p>
<p>Under the removable cover part you will find a very good mesh surface, which ensures that a radiator with a size of up to 280 mm which can optimally cool with a good deliver fresh air. Alternatively, it is also just two 140s or 120s fan positioned there. The same applies to the front, where two fans of both formats can be accommodated, while the rear has only one 120-mm fan space.</p>
<br/><br/>
<p>
<ul>
<li> Windowed Edition</li>
<li> Dimensions: 207 x 509 x 527 mm (W x H x D)</li>
<li>Material: steel, aluminum<br />
</li>
<li>Weight: 11 kg<br />
</li>
<li>Color: Black<br />
</li>
<li>Form Factor: ATX, Micro ATX, Mini-ITX</li>
<li> Front Cooling: 1x 140 / 120 mm (front, 120 mm optional)<br />
</li>
<li>Rear Cooling: 1x 120 mm (rear) / 1x 140 / 120 mm (front optional)<br />
</li>
<li>Top Cooling: 2x 140 / 120 mm (lid, optional)<br />
</li>
<li>Filters: Front &amp; Back<br />
</li>
<li>Drive bays: 3 x 5.25 inches (external) / 1 x 3.5 inches (external, instead of 1x 5.25 inch) / 7 x 3.5 inch / 2.5 inch (internal)<br />
</li>
<li>Power Supply: Standard ATX 1x (optional)<br />
</li>
<li>Expansion Slots: 8 (without tools)<br />
</li>
<li>I / O Panel: 2x USB 3.0 / 4x USB 2.0 / 1x each Audio In / Out</li>
<li> Maximum graphics card length: 428 mm<br />
</li>
<li>Features: Elements made of brushed aluminum<br />
</li>
<li>Cable Management<br />
</li>
<li>HDD and power supply decoupling<br />
</li>
<li>Removable hard disk cages</li>
</ul>
</p>
Was £114.99 Inc. VAT
Only £109.99 inc VAT.
ORDER NOW
Antec P193 Super Midi Tower - Gun Metal Black @ £76.99 inc VAT
Larger and more versatile, the Antec P193 stands apart from the competition with room to handle the biggest hardware out there. Together with Quiet Computing™ technologies like silicone grommets and sound-deadening side panels, as well as cooling features like its dual chamber design and up to seven variable-speed fans, the P193 is in a class all its own. With its larger design, the P193 can handle everything from Extended ATX motherboards to multiple graphics cards to liquid cooling and more. The P193 Performance One enclosure offers the best of everything, size and versatility alongside Quiet Computing™ and exceptional cooling.
- Dual chamber design isolates heat and noise:
- External 4 x 5.25"; 1 x 3.5"
- Internal 6 x 3.5" for HDD
- Cooling system: 1 rear (standard) 120mm x 25mm exhaust TriCool™ fan , 2 top (standard) 140mm x 25mm exhaust TriCool™ fan, 1 lower front chamber (optional) 120mm fan for HDD, 1 side (standard) 200mm fan for dual graphics cards, 1 upper front (optional) 120mm fan for HDD, 1 middle (optional) 120mm fan for graphic cards
- Cable organizers behind motherboard tray minimize cable clutter
- Front I/O Ports: 2 x USB 2.0, 1 x eSATA, Audio In and Out (HDA and AC-97 compatible)
- Double hinged door opens up to 270°
- 7 expansion slots
- 0.8mm cold rolled steel chassis for durability
- Motherboard: Mini-ITX, microATX, Standard ATX and Extended ATX
- Case dimensions: 20.25" (H) x 8.1" (W) x 23.25" (D)
- Actual clearance needed for width is 9.5" due to the side panel fan: 51.4 cm (H) x 20.5 cm (W) x 59 cm (D)
Was £84.99 Inc. VAT
Only £76.99 inc VAT.
ORDER NOW
Antec GX 700 Rugged Gaming Case @ £49.99 inc VAT
Meet the GX700, Antec’s original rugged enclosure. Now builders can assemble and expand faster with tool-less drive bays and customizable HDD trays. It is built with Antec’s signature solid steel construction and comes equipped with unique features and clean lines. Antec’s boldly designed gaming enclosure features metal clasps and rugged drive bay covers. This solid case accommodates GPUs up to 11.5” and integrates a unique flip access fan controller situated next to easy access USB 3.0 and USB 2.0 connectors. Users can cool their guns with two 120 mm top fans, capable of mounting a 240 or 280 mm cooling radiator and easily upgrade the enclosure’s five 3.5” tool-less HDD trays, each with 2.5” SSD/HDD mounts. Wherever you go, the GX700 is here for your many battles and countless victories.
- 3 + 1 x 5.25” tool-less drive bays
- Click-on 5.25” drive bay clasps
- Top bay designed for controls
- 5 x 3.5” tool-less HDD tray each with 2.5” SSD/HDD mount
- 7 x PCI-E with thumbscrew access
- Motherboards: Standard ATX, microATX, Mini-ITX
- Maximum graphics card size: up to 293 mm (11.5”)
- Maximum CPU cooler height: up to 172 mm
- Cooling system:
- Includes 2 x 140 mm top fans
- Capable of mounting 240 mm radiator for water cooling
- Includes 1 x 120 mm rear fan
- Optional 2 x 120 mm front intake fans
- Optional 120 mm side fan mount to cool graphic cards
- Water cooling support: rear water cooling grommets
- Enlarged CPU cutout
- Top I/O ports: 2 x USB 3.0 / 2 x USB 2.0 / Audio In/Out
- Unit Dimensions: 500 mm (H) x200 mm (W) x 450 mm (D)
Was £59.99 Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
CM Storm Sniper Gaming Tower Case - PURE Black @ £94.99 inc VAT
CM Storm Sniper™ Black Edition mesh version - the best gaming chassis in the world just got better, with an all black interior and 2.5" HDD/SSD support. Reinforced by CM Storm's revolutionary Storm Tactics™, with its dedicated focus on Strength, Security, and Control, the Sniper Black Edition stands ready to mobilize your next gaming session and fully back up your skills! Strength - undeniable material strength and unprecedented airflow from three huge 200mm fans. Security - the groundbreaking StormGuard™ security system efficiently protects your gaming peripherals from theft. Control - the unique control center offers convenient control over fan speeds and lights, while the sturdy carrying handles let you decide the place for your next battle. Sniper also has plenty of flexibility for water cooling enthusiasts, with radiator support and two positions for routing tubes (top 26mm and bottom 18mm).
- Material: Steel, ABS Plastic, Mesh bezel
- Dimension: (D)566.6 x (W)254.6 X (H)551 mm
- M/B Type: Micro-ATX/ATX
- 5.25" Drive Bays: 5 Exposed (without the use of exposed 3.5" Drive Bay)
- 3.5" Drive Bays: 5 Hidden
- 1 Exposed (converted from one 5.25" Drive Bay)
- 2.5" Drive Bay: 1 Hidden (Converted from one 3.5" Drive Bay)
- Cooling System: Front: 200x30mm Blue LED Fan x 1 (500 - 1000rpm, 17 - 23 dBA)
- Top: 200x30mm Blue LED Fan x 1 (500 - 1000rpm, 17 - 23 dBA)
(can be swapped for two 120mm fans or 120x240mm Radiator)
- Side: 200x30mm Blue LED Fan x 1 (500 - 1000rpm, 17 - 23 dBA)
120x25mm Fan x 2 (optional)
- Rear: 120x25mm Standard Fan x 1 (1200rpm, 17 dBA)
(can be swapped for 90mm fan or 80mm fan)
- Bottom: Supports 140mm Fan x 1 or 120mm Fan x 1 w/ Dust Filter (optional)
- Expansion Slots: Standard x 7, Special x 1
- I/O Panel: USB2.0 x 4; IEEE1394 x 1; eSATA x 1; Mic x 1; HD Audio+AC’97 x 1
- Power Supply: Standard ATX PS2 / EPS 12V (optional)
Was £99.99 Inc. VAT
Only £94.99 inc VAT.
ORDER NOW
Lian Li PC-Q05A Intel DH-61AG HTPC Case - Silver @ £49.99 inc VAT
The PC-Q05 is designed for the Intel DH61AG ultra thin Mini-ITX motherboard and the Intel HTS 1155LP heat sink. The chassis features intake vent input cooling air to cool the system down. This tiny case can house up to two 2.5" HDDs for extreme data storage.
- Case Type: Mini Tower Chassis
- Dimensions: (W) 284mm x (H) 47mm x (D) 307mm
- Front bezel Material: Aluminum
- Side Panel: Aluminum
- Body Material: Aluminum
- 5.25" drive bay (External): None
- 3.5" drive bay (External): None
- HDD bay: 2.5-Inch HDD x2
- Motherboard Support: Thin Mini-ITX (intel® DH-61AG)
- Maximum Compatibility: Cooler: support the Intel HTS® 1155LP
- Package Dimensions: (W)346 mm x 98(H) mm x 343(D) mm
- Gross Weight: 1.5 KG
- Power Supply: AC 150W adapter (not include)
Was £54.99 Inc. VAT
ORDER NOW
Silverstone TemJin TJ11 Full Tower Gaming Case - Black (SST-TJ11B-W) @ £469.99 inc VAT
In 2005, SilverStone created the Temjin TJ07, a tower chassis that was built ahead of its time with unprecedented unibody construction and compartmentalized layout for near limitless liquid cooling configuration. Then in 2006, the Temjin TJ09 was released with beautiful classic styling and advanced see-through air duct designed for cooling generations of powerful graphics cards that was yet to be released. In 2008, SilverStone broke convention and created the first retail computer chassis to implement 90 degree motherboard mounting with the RAVEN RV01, a new design that set benchmarks for balancing air cooling performance and quietness.
Not content to rest on its past achievements, SilverStone engineers aim to set yet another benchmark with the Temjin TJ11 for 2011 and beyond. The TJ11 possess all the greatest features from past SilverStone flagships products along with new designs such as the Air Penetrator fans, making it a superb chassis for cooling and low noise.In addition, there are plenty of ergonomic touches such as quick access filters, hot-swappable hard drive bays, removable motherboard tray, CPU back plate cutout, and optimized cable routing paths to enable easy maintenance/upgrade for always running as efficiently as possible.
For hardcore enthusiasts, the beautifully crafted all aluminum TJ11 is a pleasure to work with as the entire chassis is free of rivets so everything can be taken apart. It also has a bigger lower compartment than the TJ07 to house the largest radiator available such as Hardware Labs Black Ice® SR1 560 (4 x 140mm).
The potential and the flexibility of TJ11 are truly unrivaled. It can be used to build a top of the line gaming PC with its 1000W+ cooling capability on air, build an impressive storage server with its plethora of drive bay options, or build an amazing piece of technology artwork with liquid cooling.
- Compartmentalized layout from Temjin TJ07
- See-through air duct from Temjin TJ09
- 90 degree motherboard mounting from RAVEN RV01
- Includes two Air Penetrator AP181 fans to aid stack cooling
- Room for fitting powerful water cooling equipment
- Motherboard back plate opening behind CPU area for quick cooler assembly
- Support 11” wide ATX motherboard
- Dual power supply support
- Extra large venting area for 10th expansion slot
- Rivet free construction for maximum serviceability and modding
- All aluminum construction with anodized sand-blasted finish
- 9 x 5.25" Drive Bays
- 6 x 3.5" Hot Swap Drive Bays
- 3 x 2.5" Drive Bays
- Side Cooling: 2 x 180mm AP181 fan,700/1200rpm 18/34dBA
- Top Cooling: 1 x 120mm exhaust fan, 900rpm, 18dBA
- Bottom Cooling: 2 x 120mm AP121 intake fan, 1200rpm 19dBA
- Expansion Slots: 10
- Front I/O Ports: USB3.0 x 2 / USB2.0 x 2 / Audio x 2
- Fits Graphics Cards up to 12.4"
- Dimensions: 224 mm (W) x 642 mm (H) x 657 mm (D)
Was £499.99 Inc. VAT
Only £469.99 inc VAT.
ORDER NOW
Thermaltake Armor Revo Gaming Case - Black/Blue @ £129.98 inc VAT
Gamers and PC enthusiasts have long revered the Thermaltake Armor as an excellent and spacious chassis to house a high performance rig. With the Thermaltake Armor Revo's pure aesthetic gaming design and engineering deliver impressive amount of features that not only looks awesome but also fully integrated as well. From the inclusion of the latest internal USB 3.0 header to the ability to support high-performance 24cm water cooling radiator, the Armor Revo has the best of both world. While many other chassis claims high airflow design by stuffing as many fans into the case as possible, Thermaltake engineers placed three oversized 200mm blue LED fans and a 140mm rear exhaust fan in strategic locations, in addition to the CableClear cable management, to not only improve overall airflow but to prevent airflow blockage as well.
- Dimension (H x W x D): 586 x 254 x 552 mm
- Side Panel: Transparent Window
- Colour: Exterior & Interior : Black
- Material: SECC
- Cooling System: Front (intake) : 200 x 200 x 30 mm Blue LED fan x 1 (600~800rpm, 13~15dBA)
- Rear (exhaust): 140 x 140 x 25 mm Turbo fan (1000rpm,16dBA)
- Top (exhaust): 200 x 200 x 30 mm Blue LED fan (600~800rpm, 13~15dBA) / 140 x 140 x 25 mm or 120 x 120 x 25 mm (optional)
- Side (intake): Plug&Play 200 x 200 x 30 mm fan (600~800rpm, 13~15dBA)
- Bottom (Intake): 120 x 120 x 25 mm (optional)
- Drive Bays: Accessible: 4 x 5.25’’, 1 x 3.5’’ (Converted from one 5.25” drive bay)
- Hidden: 6 x 3.5’’ or 2.5’’
- HDD Docking: 1 x 3.5’’ or 2.5’’
- Expansion Slots: 8
- Motherboards: 9.6” x 9.6” (Micro ATX), 12” x 9.6” (ATX)
- I/O Ports: USB 3.0 x 2, USB 2.0 x 2, eSATA x 1, HD Audio x 1
- PSU: Standard PS2 PSU
- LCS Upgradable: Supports 1/2”?3/8”?1/4” water tube
- Other: CPU cooler height limitation: 180mm / VGA length limitation: 330mm
Was £139.99 Inc. VAT
Only £129.98 inc VAT.
ORDER NOW
Thermaltake Level 10 GT Visionary Full Tower Case - Black @ £194.99 inc VAT
Following the high-profile launch of Level 10 Super Gaming Modular Case, the design collaboration between Thermaltake and BMW Group DesignworksUSA, in 2009, Thermaltake looks to invigorate the PC enthusiasts with the latest Level 10 GT computer case. The design language of the Level 10 GT expresses a passion for visual aesthetics deriving from demanding and immersive game play and multimedia entertainment enthusiasm. Modern games and entertainment applications also require highly advanced hardware configurations, which at the same time request more space and optimized ventilation than conventional hardware. With EasySwap Pitstop 5 every HDD/SDD has its own removable tray, EasySwap in hot-plug mode within seconds. With this users have greatest storage flexibility and maximum data transfer speeds you need. Modern multimedia peripherals operate at tremendous data transfer velocities, with 2 USB 3.0 connectors right on the top of the Level 10 GT you be guaranteed to always enjoy SuperSpeed entertainment. The concept of the clear lines of the outside design of the Level 10 GT is just as well continued in the inside. An advanced and highly convenient cable management bundles respective cables almost like in tunnels behind a back plate. Your system shines in clarity, easy access to all components is warranted for and even ventilation is greatly improved. High tech components are prone to heat impacting longevity and performance. For this vital reason the implementation of Thermaltake's QuadFan (of which three also feature ColorShift) Ventilation concept creates an ideal environment for your components to unfold their full potential. Perception of what and how it is surrounding us, can have strongly inspiring, motivating and vitalizing effects on us. With triple ColorShift three LED fans with five sets of illuminations let you get into the driver seat of your respective moods. Or if so wanted, you turn them all entirely. At times enthusiasm may push you to the ultimate limits, to where you have not been before. Particularly for those who are bound to go beyond these restrictions, i.e. tune and clock your setting, further measures to keep the heat down might be asked for. Ready for Liquid Cooling Systems you can rest assured to keep your coolness. Powerful performance needs space to unfold, this is also the case for highly advanced graphics cards, which the length has grown considerable over the past years and is most likely to grow even further in the future. With space for up to 37 cm oversized cards, there is sufficient space to stay future proof.
- Performance cooling made quiet: one top 200mm exhaust fan, one front 200mm intake fan, one side 200mm intake fan and one rear 140mm exhaust fan.
- Hinged side panel to enable easier opening of the side door and access to computer for maintenance or upgrade.
- Dramatically improved cable management. User no longer "hides" the excessive cable on the back, the Level 10 GT features numerous holders designed into the chassis for cable management.
- Five hot-swappable hard drive bays, each with its dedicated backplane to support hot-swap. Hard drive mounting supports both 2.5" or 3.5" drives.
- Connectivity array. Four USB 2.0 ports are conveniently located on the front bezel including a pair of audio ports. Two USB 3.0 ports and one eSATA port located on the top.
- Water cooling ready - 120mm or 240mm radiators can be easily attached to the top side of the chassis (top 200m fan needs to be removed)
- Fan speed management control embedded. ColorShift fans can be easily controlled through controls on the top.
- Fully black-powdered interior.
Was £209.99 Inc. VAT
Only £194.99 inc VAT.
ORDER NOW
might have to grab me one of those revo cases
would go well with my original armour case :D
aww, i crossed my fingers and hoped for some mitx sugo's before i clicked the thread :(
i guess the lian-li must only take a picopsu?
