*** Easter Weekend Deals *** PSU ROUND
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys
To celebrate Easter we are offering deals for the weekend, this mornings first offering is Power Supplies!
OCZ ZT 750W '80 Plus Bronze' Modular Power Supply @ £79.99 inc VAT
The ZT series is the superb choice for performance and power users who need solid, reliable PSU. With a completely modular design, ZT Series keeps your internal case environment organized by eliminating wire clutter and improves airflow by using only the cables you require. Kept supremely cool with a load-controlled 140mm fan, the OCZ ZT Series PSU was engineered to be ultra-quiet by eliminating distracting noises from your PC when working or gaming. With an 80-Plus Bronze Certification featuring up to 85% efficiency under typical load environments, this power supply remains rock solid and stable.
- Single +12V rail for efficient power distribution
- Heavy-duty protection circuitry
- Fully Modular Cabling System
- 80-Plus Bronze Certified (85% efficient at typical load)
- 140mm ball-bearing fan
- Dimensions: 150 x 86 x 175mm (W x L x H)
- Rated at 45°C ambient
- Premium 105°C electrolytic capacitors
- Erp compliant, low power usage in standby mode
- Active PFC
- ATX 12V 2.2 Compliant
- MTBF: 100,000 hours
- 5-year warranty
- 1 x 20+4-pin ATX
- 2 x 4+4-pin ESP/12V CPU
- 4 x 6+2-pin PCI-E
- 6 x 4-pin Peripheral
- 9 x 5-pin SATA
- 1 x Floppy
Was £89.99 Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
OCZ ZX Series 850W '80 Plus Gold' Modular Power Supply @ £139.99 inc VAT
The ZX Series is the unsurpassed solution for driving today's Enthusiast and gaming systems. It has the ability to easily power both NVIDIA® SLI™ and ATI CrossFire™ modes, supporting even the most power hungry GPUs with multiple GPU configurations. Industrial-grade yet designed with enthusiasts, gamers and modders in mind, this PSU is stable, robust, and sports a sleek look and the most compact form factor of its class.
Kept ultra-cool with a load-controlled ultra quiet 140mm fan, the ZX Series was engineered to be the quietest PSU available and eliminate distracting noises from your PC. Highly efficient, featuring up to 92% efficiency at typical load and up to 89% at full load, this leading-edge power supply remains rock solid and powerful while retaining superior efficiency under load. The OCZ ZX Series provides universal Input and Active PFC (Power Factor Correction) to effectively regulate input voltage across worldwide power grids and maintain an economical, stable supply of power.
Backed with OCZ’s 5-year “power swap” warranty, the OCZ ZX Series PSU gives you the ultimate power and peace of mind to ensure the stability, low noise, optimized air flow, and efficiency of your gaming system.
- 850W Continuous power
- Ultra quiet 140mm ball-bearing fan
- +12VDC @ 70A Single Rail Design
- SLI™ and CrossFire™ support
- Fully modular cable management system
- 150 x 175 x 86mm (W x L x H)
- ATX12V v2.2 and EPS12V
- 80-Plus Gold Certified
- 92% Efficiency (Typical Load)
- Overvoltage/Overcurrent/Short-Circuit protection
- Active PFC
- 5 year warranty backed by OCZ's exclusive
- PowerSwap Warranty replacement program.
- 20+4 pin ATX
- Dual 4+4 pin CPU
- 4 x PCIe 6+2 pin
- 12 x SATA
- 9 x Molex
- 1 x Floppy
Was £149.99 Inc. VAT
Only £139.99 inc VAT.
ORDER NOW
XFX 850W XXX Edition Modular '80 Plus Silver' Power Supply @ £89.99 inc VAT
The XFX XXX 850 watt modular power supply gives you the power you need with a brilliant combination of form and function. Giving more than just life to your PC, this power supply allows easy cable management with modular connectors which helps increase airflow. With tight voltage regulation and high efficiency operation up to 88% (80 Plus Silver) this power supply will give you exactly what you need to keep your gaming charged and ready.
- 850W of continuous power at 50°C
- 80 Plus Silver Rating
- SLI Ready
- Detachable Modular Cables
- High quality Japanese brand capacitors (105°C)
- Tight voltage regulation (±3%)
- High efficiency operation up to 88% (80 Plus Silver)
- Single, high power +12V rail (up to 70A/840W)
- DC to DC Voltage Regulator modules for +3.3V and +5V
- Solid polymer caps provide enhanced reliability and stability
- Quiet 135mm ball bearing fan provides superior cooling
- Supports multiple high-end graphic cards (SLI & CrossFire)
- Active Power Factor Correction
- 5-year Limited Warranty
Was £99.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Cooler Master Elite Power 500W Power Supply @ £28.99 inc VAT
The reliable, efficient and affordable line of Elite power supplies is ideal for mainstream and basic computing systems. Built with quality components and dual +12V outputs, the Elite series is fit to handle demands of high power requirements. The eco-friendly design allows the Elite series to reach more than 70% efficiency at typical loading and meet Energy Star and Blue Angel requirements.
- Compliance with the newest Intel standard ATX 12V V2.3
- More than 70% efficiency at typical load operation
- High performance components design for better reliability
- Green power design to meet Energy Star and Blue Angel requirements
- Multiple protection design(OVP/OCP/OPP/SCP)
- Support dual +12V1 and +12V2 outputs for higher power usage
- One 4+4 pin +12V CPU connector for high-end CPU
- EMI and Noise filter built in design
- 2 Year warranty
Was £32.99 Inc. VAT
Only £28.99 inc VAT.
ORDER NOW
Antec High Current Gamer M 520W "80+ Bronze" Modular Power Supply @ £63.98 inc VAT
Antec's HCG M power supplies are the perfect combination of power and efficiency. The HCG M features special heavy-duty High Current connectors and cabling that supply extreme levels of power, and superb efficiency thanks to 80 PLUS® Bronze certification and Active PFC. Highest-quality connectors, Japanese-brand capacitors, and a quiet 135 mm double ball bearing fan complete the package. The HCG-520M features High Current Cable Management and 10-pin modular connectors. If loads of power, High Current engineering and extreme efficiency are what you're after, the HCG M is the PSU for you.
Features:
- 520 watts of Continuous Power
- 80 PLUS® Bronze certified — up to 87% efficient
-High Current Hybrid Cable Management — special 10-pin and 5-pin modular connectors for High Current rail
- Quiet 135 mm Double Ball Bearing cooling fan
- Stealth Wires: all wires darkened for minimal visibility in chassis
- All Japanese brand capacitors for reliability
- Thermal Manager: an advanced low voltage fan control for optimal heat & noise management
- Up to 90% power available on +12V rail
- ATX12V version 2.32 and EPS12V version 2.92 compliant
- Heavy-duty protection circuitry on all rails prevents damage from a variety of dangers:
- Over Current Protection (OCP)
- Over Voltage Protection (OVP)
- Under Voltage Protection (UVP)
- Short Circuit Protection (SCP)
- Over Power Protection (OPP)
- Surge & Inrush Protection (SIP)
- AQ5 — Antec Quality 5 year limited warranty on parts and labour
- MTBF: 100,000 hrs
- POWER SUPPLY CONNECTORS ASSORTMENT:
- 1 x 24(20+4)-pin
- 1 x 8(4+4)-pin ATX12V/EPS12V
- 2 x 8(6+2)-pin PCI-E
- 5 x SATA
- 4 x Molex
- 1 x Floppy
- Safety Approvals: UL, cUL, CE, TÜV, CB, FCC, CCC, C-Tick, BSMI
- Net Weight: 1.8 kg / 4.0 lbs
- Size:
- 86 mm (H) x 150 mm (W) x 160 mm (D)
- 3.4" (H) x 5.9" (W) x 6.3" (D)
Was £73.99 Inc. VAT
Only £63.98 inc VAT.
ORDER NOW
Corsair Enthusiast Series TX 850W V2 High Performance '80 Plus Bronze' Power Supply (CP-9020043-UK) @ £94.99 inc VAT
The Enthusiast Series TX V2 is part of Corsair’s best price-performance range of power supplies, designed to meet the exacting standards and performance needs of demanding enthusiasts. TX Series power supplies are ideal for performance enthusiasts who require an affordable, high-wattage, reliable and highly efficient PSU. Corsair TX V2 Series PSUs are compatible with the latest Intel and AMD platforms and NVIDIA and AMD multi-graphics configurations.
- The latest ATX12V v2.31 and EPS 2.92 standards and it is backward compatible with ATX12V 2.2 and ATX12V 2.01 systems.
- An ultra-quiet double ball-bearing fan delivers excellent airflow at an exceptionally low noise level by varying fan speed in response to temperature.
- 80PLUS Bronze certified, delivering up to 85% energy efficiency at real world load conditions.
- Active Power Factor Correction (PFC) with PF value of 0.99.
- Universal AC input from 90~264V. No more hassle of flipping that tiny red switch to select the voltage input!
- A dedicated single +12V rail offers maximum compatibility with the latest components.
- Over-voltage and over-current protection, under-voltage protection, and short circuit protection provide maximum safety to your critical system components.
- High-quality Japanese capacitors provide uncompromised performance and reliability.
- A five year warranty and lifetime access to Corsair¡¦s legendary technical support and customer service.
- Safety Approvals: UL, CUL, CE, CB, FCC Class B, TUV, CCC, C-tick.
Was £109.99 Inc. VAT
Only £94.99 inc VAT.
ORDER NOW
