Easy 5930k overclock
13 Jan 2012
United Kingdom
Hi guys
I'm looking for a simple, no hassle easy overclock for my 5930k (would like to keep it around the 1.20 - 1.25v ballpark)
i was wondering if just tweaking the Vcore and multiplier would suffice? at the moment im test 1.20v with 4.3 on multiplier
So Far I have got it to 4.4ghz using 1.25V and changing nothing else, I disabled Intel speed step and C States
Temps are around 30-40 degrees idle and 50-65 degrees on load with a h105
I use 1.25OC volt + 0.75 Offset voltage, Adaptive too and that gets me 4.6ghz. Sadly thats the most my cpu will do even if I throw more volts at it.
