EASY Excel question....making the cells 'normal' again?
Consigliere
12 Jun 2004
SW17
Just filled in some cells but changed my mind about the colour. Now there are no 'borders'. :o I've tried a few options but i'm tired and need a quick solution. So how can i make the cells look like the rest again?
Hmm.... I assume you're using office 2003 then?
This is what I was talking about:
I'll try to find the same thing in 2003 for you.
EDIT: Select the cells, then click on Format > Style, and select "Normal" in the drop-down list and click OK.
Ahhhh, yeah got it. Cheers.
Any ideas how to make my 'Currency' show negative numbers? It is meant to show '-18.50' but it doesn't. It just shows '0.00'.
Is the cell formatted as currency?
I just tried that and it works, just type in "-18.50" and it will automatically add the "£" sign.
