- 4 Mar 2016
Hi guys, this is my first case mod (apologies if this is super simple compared to what you're used to seeing!!) but this is my guide to making a cheap, easy PSU shroud using sheet aluminium and some spray paint.
What you will need:
- 2mm Sheet aluminium
- Tin snips
- 3 planks of wood
- C clamps (optional)
- Spray Paint (Matte)
Step 1: Measure the space you want to cover. I measured the depth, width and height of the area, and then marked out that area on the aluminium sheet and cut to size.
http://cdn.overclock.net/2/2d/2dda3e5d_Step1.jpeg
Step 2: Set up a bending jig for the metal. Mark the line you want to bend along. I used my sliding workbench to secure 2 safety planks of wood to protect the bench, however placing the wood on a table with C clamps will also work nicely.
http://www.overclock.net/content/type/61/id/2726409
Step 3: Use the 3rd plank of wood to evenly distribute force along the metal, keeping the force applied as close to the bend as possible, imitating a metal brake.
http://www.overclock.net/content/type/61/id/2726411
Step 4: Spray several layers of thin coats at 20 minute intervals and then leave overnight to dry through.
http://www.overclock.net/content/type/61/id/2726412
Step 5: Place in the case, and you're done! I plan to spray a decal on at some point and will update as soon as possible!
http://www.overclock.net/content/type/61/id/2726413
http://www.overclock.net/content/type/61/id/2726414
http://www.overclock.net/content/type/61/id/2726415
What you will need:
- Tin snips
- 3 planks of wood
