Easy question about the iMon remote
23 Nov 2007
Midlands
Does it have a strong remote signal?
Some infra red remotes i've come across in the past work from any angle and even operate the device if something is blocking the path of the signal whereas other infra red remotes require you to point it directly at the device and if something blocking the path it, it won't work.
Which type is the iMon remote?
