Easy to reverse case ?
14 Sep 2012
Behind you
I'm sick to death of having spent a fortune, on my rig, and loop, and not really being able to look at it, to appreciate the hard work that has been put into it, as it needs to be on my left, and not the right of me. i can see it now, but I would rather the case be against the wall, to my left and not against the wall, just behind my speaker, and monitor.
So my questions are,
1, How hard is it to reverse a case, so that the window is on the right ?
2, What case would you recommend, to reverse, it needs to be a good size, as in no smaller than the Enthoo Luxe, in order for my rads to fit in, at least a 240 and a Monsta 420.
here is the problem.
No mate, it can be done, the Switch 810 was an old fav for modders to reverse. I'm just not sure what the requirements need to be to make it an easy change.
