Before I start this - I know very little about SQL
Weve been asked to look at a server to see if theres any problems because a database upgrade is taking longer than usual.
The guy doing the upgrade says that this process normally takes 2-3hrs on his home PC but the server is taking 10hrs or so to do this conversion or upgrade.
The server itself only has 4gb of RAM and half of that is pretty much constantly used by SQL so Im sure that doesnt help. Also, I found that the SQL files werent excluded from the AV scanning so Im sure that had a hit on the performance lol. The other 2gb of RAM is used up by Exchange and other bits and bobs.
Aside from that, the server looks ok, CPU usage is low and the server responds fine when being used.
What Im looking for is an easy to use utility so I can compare performance from this SQL database to another one. It either needs to pretty much run itself or come with some half decent instructions lol.
If there isnt one then I guess we'll have to do without lol
