easy tune 5
12 Dec 2007
my motherboard utility disc came with this program. i have installed it and looked at it but as my knowledge is limited i'm not too sure whether i should change anything!
is anyone familiar with this program?? can you help me??
oh and btw what temp should my cpu be running at?
Hi :)
Easy tune can change your FSB on the fly in order to overlcock your system, and can change voltages (with a reboot). Before using this application, I'd recommend taking a read of some of the guides in the overclocking section - you'll find a lot more help on this over there.
Your CPU temp depends entirely on what cpu you have, but most people try and stay under 60C. Again, you'll find much more help in the overclocking section :)
