easy tune 6 not displaying correct cpu temperature.
26 Sep 2013
here is my build (its a screenshot): http://prntscr.com/219utw
ive tried many other temperature showing applications such as cpu-z and none of them show any temperatures. easy tune 6 was the only app that even showed a result, in the end i found out it is showing the wrong temperature this is because when i went into the bios my cpu was running at 41 ish degrees Celsius, on easy tune 6 it is showing that my cpu is running at 20 ish degrees Celcius.
anyone else had this problem and found a solution?
